which images are affected?
looks ok to me…?
but if you mean only partialy uploaded images, then try ticking use the file rename in the connections setup (your ftp server may or may not like it)…that way the image is only made avaialble to view once finished uploading
also, you need to setup your extra sensor graph to display the data:
click on setup there, then tick display for the sensors you want to display, then click on set for each
I checked the box like you suggested. It still truncates the main display image and the real time graph. Sometimes it cuts off the summay image also. :x
do the images look ok in your web files folder?
maybe try increasing the ftp time out in the connections setup
any errors under ftplogfull.txt (i.e view, ftp error log, view full log)
Got it! :lol: In the FTP log I saw some failed transfers due to running out of space. I went in and deleted some of the old history files and everything works like a champ now. Guess I need to do some housekeeping occasionally. Those little 13K .gif files really add up!
