I know I am not setting WDL up correctly. No matter what I try when I surf to my weather site all I have is my WD weather page. I cannot get WDL to post. Is there some change I need to make in WD so the live page will upload and not my standard WD page. I have followed the setup procedure, and even used the WDL configurator to set up page. I know it is in my folder setup somwhere. If someone with patience could help I would be grateful! When you are 57 and not born in the computer age things are difficult!
Your website link doesn’t work, please provide the URL of your site so we can try to help.
Sorry. http://home.comcast.net/~grahamgr/mypage/
the upload link is http://upload.comcast.net/~grahamgr/mypage/index.html
what is the URL to your WDL html page?
This is the only page I have. I want to use it for WDlive instead of WD. That is what I need to know, how to change over.
upload the WDL html file to your web site
and call it say
wdl.html
then you can provide a link to that
make sure you also upload the other needed WDL files and have WD set to upload the clientraw files
Next question, where in the setup and how do I upload the wdl.html file to my site. I am lost here, sorry. This is not an easy process for me, but I won’t give up until I see it through. If I can get this working I am going to purchase wdl. That is why I want it to work.
WDL has a built in FTP program in the configurator setup
or you can use the manual ftp upload in WD, in the ftp/internet setup
and set the remote file name there
once you get this all working, then you can stop the WD uploaded index.html file and set the WDL upload files as index.html instead
I have the clientraw realtime ftp working but the page is not there still the regular wd page. Here is the data transfer
TYPE A
200 Type set to A.
PASV
227 Entering Passive Mode (216,87,188,9,190,222)
STOR clientraw.txt
150 Opening ASCII mode data connection for clientraw.txt.
226 Transfer complete.
File uploaded at time :22:19:22
TYPE A
200 Type set to A.
PASV
227 Entering Passive Mode (216,87,188,9,191,11)
STOR clientraw.txt
File uploaded at time :22:19:47
TYPE A
200 Type set to A.
PASV
227 Entering Passive Mode (216,87,188,9,191,47)
STOR clientrawextra.txt
150 Opening ASCII mode data connection for clientrawextra.txt.
File uploaded at time :22:20:12
TYPE A
200 Type set to A.
PASV
227 Entering Passive Mode (216,87,188,9,191,61)
STOR clientraw.txt
File uploaded at time :22:20:22
TYPE A
200 Type set to A.
PASV
227 Entering Passive Mode (216,87,188,9,191,84)
STOR clientraw.txt
File uploaded at time :22:20:37
TYPE A
200 Type set to A.
PASV
227 Entering Passive Mode (216,87,188,9,191,124)
STOR clientraw.txt
File uploaded at time :22:21:2
TYPE A
200 Type set to A.
PASV
227 Entering Passive Mode (216,87,188,9,191,163)
STOR clientraw.txt
File uploaded at time :22:21:27
I still cannot wrap my brain around this. That is what I mean by patience! Now even my wd wont upload. I’ve gone backwards!
Weather Display uploads are working again. Had to reset file folder to upload. Still no WDL.
upload the WDL html file , from the upload folder, where you have WDL installed
to your web site as wdl.html, using the manual upload in WD (where you can set the remote file name)
thats the first step
I cannot find a WDL html file in the upload folder. there is an index html file. Is this the one I upload as wdl.html
Ok I have something?
12345 0.0 0.0 225 19.6 76 1015.2 0.0 0.5 0.5 0.000 0.000 26.3 34 0.0 4 0.0 0 0 0.5 -100.0 -100.0 -100.0 -100.0 -100.0 -100.0 -100 -100 -100 00 11 41 Mosheim_Weather_Live-12:11:41_AM 0 0 16 5 100 100 100 100 100 100 100 19.6 23.7 19.7 19.6 0 Night_time/Night_time 0.3 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0.0 15.3 1791.3 5/16/2010 23.9 23.7 19.7 19.6 0.0 0 0 2 0 0 0 0 0 0 0 20.2 20.1 20.1 19.9 19.9 19.8 19.8 19.7 19.6 19.7 0.5 0.5 0.5 0.5 0.5 0.5 0.5 0.5 0.0 0.0 19.7 19.6 19.6 0.0 0 — — 225 0 0 -100.0 -100.0 -100 0 0 0 0 0.0 26.3 26.2 21.1 1015.2 1015.2 5 11:26PM 5:09_PM 21.3 21.1 15.3 15.0 0 2010 0.0 -1 1 -1 33 55 191 137 147 202 225 225 225 225 0.0 0.0 0.0 17.0 36.20000 82.25000 0.5 76 75 0.0 12:00_AM !!C10.37P!!
This is on my page now! It has the page title Mosheim weather live. How do I get my config file to load.
Past midnight my time. Will work on this later.
you need to upload the WDL html file from the upload folder where you have WDL installed
the file will be called index.html
and you need to upload that as wdl.html and not index.html, as otherwise your default WD upload will overwrite that file name
(unless you disable that)
Highland Piper - I’m also 57 but an IT (Software Development) Manager - even so, I still had to put quite a bit of time into WD & WDL to get things working how I wanted them (still tweaking now) so keep at it, you’ll get there in the end.
remote access to your PC would be one solution HighlandPiper
Ok Windy I am back. If you will tell me how to allow I will use remote access!
