Brian, if you recall a few months back that I reported a problem with the minimum soil temperature. The data recorded for it doesn’t always seem to be retained when I either reboot WD, or if I reboot for an upgrade.
The way over it is at present is that I have to write down the information before I exit the program, just incase it looses it on boot up.
If it does, I have to go to Action/reset daily extreme values and then go to minimum soil temperature. Likewise, I have to do the same for Action/reset selected all time record values and select minimum soil temperature there too.
Yes, I can put up with it, but could you check again if the time delay you have inputted is sufficient to enable the existing data in this section to be acknowledged before it places 0c in this field.
Seems funny it only does it for minimum soil temperature!
