It’s been working no problem since last June. Now, when WD comes up, it doesn’t connect the first time. I have to unload and reload, sometimes twice to get it to connect. Once it connects, it’s good.
Running version: v10.37Q-(b41)
System OS: XP SP3
Dell Computer
VVP version: 1.2.1.1
Similar issues here and looks like we have very similar configurations. I upgraded from 10.37Pb15 last month and nothing but issues. Brain has looked into and resolved most. The others I figured out myself, or thought both forums.
I noticed over the weekend a FLAT LINE (no data change) that started on the 16th. It looks like VirturalVP was sending o.k. and three weather programs (WeatherLink, VWS & VPLive) were receiving except for WD. This issue caused my CWOP stats to go south and even WUnder took me off-line due to bad data. I had another issue on the 15th where 10.37Q41 just stopped updating all together; however VirturalVP shows no issues with WD. I tried changing WD from Serial-USB to IP; however after an hour or so a few times it stopped getting updates from VirturalVP so I went back to old config. I’m now using VWS to update WUnder and I’m thinking of changing CWOP to one of the other programs also. I spent a ton of time deleting all the bad data on WUnder (which there was a bulk delete) and re-sent all data for the 17th (still working on the 15th).
10.37Qb41 looks like it was re-compiled on 4/14 based on date/timestamp so I re-installed it Sunday. I also updated VirturalVP to 1.2.5, even though the only issue was with WD. I’ve been baby sitting my dedicated weather computer for 3 days now and all is still good; however I’m VERY frustrated in upgrading from a very stable (other than some memory leaks) version of WD (10.27Pb15) and I’m really thinking of going back to it. I can’t remember why I upgraded in the first place as I’m not a believer of keep fixing things (new versions) until it BREAKS!!!
I’ve had this configuration since Jan '10, so I know it’s not VirturalVP or anything else except WD
WDisplay has been up for 6 1/2 days without any “Flat Lines” or loss of communication from VirtualVP. XP PC has been up for 7 days without a reboot. StartWatch only shows one kill/restart of VWS during the week (typical).
Maybe this new configuration with re-complied 10.37Qb41 and VirturalVP to 1.2.5 might be the ticket.
Using weatherlinkIP
I have to reboot to connect Only when I update WD to latest version. Otherwise I have WD start 1 minute after VVP, always connects for me.
Startwatch starts VVP 1min after it loads, then 1 min later WD starts, then 5 min later WxSim, etc
WinXP on dedicated netbook.
WDisplay has now been up for a month (WOW) without any “Flat Lines” or loss of communication from VirtualVP. My dedicated Weather Station PC running Windows XP SP3 hasn’t needed a restart for 47 days (Double WOW!!!). StartWatch only shows kill/restart(s) of VWS (typical) which I’m thinking of removing it completely; however I use VWS to send data to WUnder due to an issue I was having with a previous build of WD 10.37Q.
From my system status page:
Webserver up for: 245 days 22 Hours 16 Minutes
Station system up for (uptime for windows on weather pc): 47 Days 0 Hours 10 Minutes 12 Seconds
Station system free memory (amount of free memory on the pc): 150.000 MB
Weather Display last started: 9:25:17 5/12/2011
This new configuration with a re-complied version of WD 10.37Qb41 and VirturalVP upgrade to v1.2.5 rocks solid!!!
Windy,
As stated in my 1st reply this tread (summarized as):
Upgrade from WD v10.37Pb15 to V10.37Qb?? caused FLAT LINE (no data change). VirturalVP was sending o.k. and three weather programs (WeatherLink, VWS & VPLive) were receiving o.k. except for WD. This issue caused my CWOP stats to go south, and WUnder took me off-line due to bad data (FLAT LINE, no data change).
This is the reason I starting using VWS to update WUnder. I spent a ton of time deleting all the bad data on WUnder and re-senting data for the that period of time caused by the FLAT LINE.
Since I installed your re-compiled v10.37Qb41 (4/14/11 based on date/timestamp), and updated VirturalVP to 1.2.5 I haven’t seen any FLAT LINE issues.
Now that I’ve seen such a good WD uptime, with no issues it’s time for me to think once again about using WD for WUnder data sending and possibly retiring VWS once and for all.
