NOAA WARNINGS not working now
As I said in post…tried BOTH…
worked for a while then not…with old zone formats and new county format…
I think Brian may soon be making more changes?
Yes, he is making the needed changes. I am testing them for him, but its not done yet and not ready for prime time. Like i said: Stand by.
You cannot make the old version work. NOAA has changed the format of the warning. Brian will release something as soon as its ready. I prefer he release something that actually works. STAND BY.
Thanks Brian…that is working now. Will there be an eventual change to the custom tag for %NOAAEvent%? to coincide with this new process?
Did not find my State, nor zip but I knew my county code and that did work by manually entering it.
Use the address lookup if you don’t know your code.
Jim
there is a new field with ver 7 of wdwarning email exe for postal address
So I found out I can’t manually enter my zone, it will not save it. I doesn.t seem to find anything for New Hampshire.Shsnipould be NHC013
I might be wrong, it used to save it in the bottom line, if I click on go it appears to work. Things just changed from what I am used to seeing.
Did you enter your postal address?
Yes, It appears to work, but when go back to NOAA warnings, all the boxes are blank. Might not work like it used to. Clicking go and it appears to work, it will fill in the blank line with the correct URL, close it, open it and line is blank till I click go.
I will say it is working, will keep an eye on it, should have a wind warning in the next 24 hours.
Turn the Setup switch off. Enter your County Code.It’ll save it.
Jim
