I think I finally found what I was looking for - Noaa style email report and upload.
My question(s):
At the bottom of the screen (view>NOAA reports), I have it set to email the NOAA style report, and upload the NOAA report. It says below that the email settings in FTP email settings are what it uses - fine. But, does that switch in FTP email settings need to be on? Also, will the email be sent at the times set there.
And, at what time does the NOAA report get uploaded to the web? Is it done in the middle of the night with the averages/extremes?
And…another small problem
If you look at the screen shot, notice the line "day temp high time etc. strings out longer than the figures below - they are not lined up. Is there a way I can line these up?
Your
[code:1]
[/code:1] tag should tell your browser that is reading the html text to use a mono-spaced font.
Not having access to the same report you have, I cant try it with one, but I suspect using a monospaced font will make it look right.
Ok - figured out most of this on my own - the email & web report send just after midnight without the email switch being on in FTP email.
A little bug I’ve found in the report -
The times are in 24hr format, but also have an “a” or “p” after each time. Can this be fixed? I need it to be looking right so it can be copy/pasted for a newspaper.
http://weather.sterlingrun.com/dailynoaareport.htm
Still haven’t figured out why the email is truncated.
