NOAA/NWS Alert access problem in my recent install **Solved**
A NOAA/NWS alert has appeared in the upper left small block but when clicked results in this notice: “Forbidden You don’t have permission to access this resource.Server unable to read htaccess file, denying access to be safe.”
Any suggestions on how to fix this? Thanks. —Bill
https://pwsdb.sartelleastweather.com
This is the link used in the iframe:
https://pwsdb.sartelleastweather.com/nws-alerts/nws-summary.php
It should work in the browser also, but as you can see, it only displays the error message.
Please check the permissions of the nws-alerts/ folder, sub-folders and files using your ftp program.
After first install the very old :slightly_smiling_face: data of the test-area will be shown as in this example
https://pwsdashboard.be/pwsWD/nws-alerts/nws-summary.php
Fixed. That did the trick. Thanks, Wim.
—Bill
