No winddir icons in yrno forecast Graph version
The windicons do not display in the forecast, forecast 6 hours and forecast per hour.
The abbreviation for the direction is missing in the link.
It just says .svg
https://www.westland-depoel.nl/pwsWDVV/img/windicons/.svg
I understand this version of the yrno forecast does not come standard with the pws-dashboard download.
Installed version is 01|2023-04-27
Current 01|2021-12-08
yrno graph forecast
TIA
Please always do a test first, either in the debug-dashboard
or directly
https://www.westland-depoel.nl/pwsWDVV/_test.php?test=fct_yrno_popup.php
Enough errors to start with.
For an up-to-date 2012-lts website:
Attached fct_yrno_popup.php version for PHP 8.2 and the windlabel function
First test it as . . /pwsWD/_test.php?test=fct_yrno_popup2.php
If it works Ok, rename the current fct_yrno_popup.php to old_fct_yrno_popup.php
And rename the fct_yrno_popup2.php to fct_yrno_popup.php
fct_yrno_popup2.php.zip (14.7 KB)
Heel erg bedankt.
Windicoontjes zijn er weer.
Many Thanks!
Working again.
