No Indoor Humidity with WD-9.53a as client
I am using WD (Now 9.53a) at home (Server) and at work (Client). The client setup will not display indoor humidity. (Indoor Temp. is displayed correctly.)
But if I set all current data to be displayed using LCD display then the indoor humidity data (24%) is displayed but the title is not.
(Note: title is set to show “Indoor H”)
do you have ticked the indoor hum/temp option under the client/server setup?
Yes, just checked both the server and client setup. Both checked.
Not sure if this is related to the problem but since about version 9.49 the Start in Center for 800x600 YES/NO will not stay checked YES and does not start in center after save/exit and restarting. The program starts in the lower right of the screen.
