New Webcam Setup - locks up
Brian;
Version 10.17-Beta - After going through the new web cam setup all worked fine for about 5 hours, then it stopped recording the camera completely.
This a.m. I went back into the setup and the picture it was showing in the camera setup page was the frozen image from late yesterday, then on the second setup screen, it appears to have been showing the actual camera image as it was black as it should be with it being nightime. I went through the reconfiguration again, slooowwwly responding and upon exiting back out of the webcam setup, the dreaded MS XP error message came up and it closed down WD. :frowning: (The usual XP plain vanilla variety message stating the program has caused an error and XP is shuting down the application)
Restarted WD - no soft boot - and it appears to be capturing the data again, eventhough it is nighttime here. I had gone into the setup screens yet again and exited without a problem. Go figure :?
been going all day here OK…
I did have it at one stage where it bogged down WD
but restarting fixed it…
see if it does it again…the stuck image…
do you have the live switch ON?
i have that on,.try that maybe,…
Yes, live switch was on. So far so good as its been running about 2 hours now and still going. :slight_smile:
Brian;
:cry:
Not too good with this version. At 00:19 this a.m. the webcam picture froze again and along with this, my CPU usage for WD was hanging at 50-54%-consistantly. I was finally able to enter into the webcam setup and tried to get it to reconfigure and that phase finally was so bad I couldn’t get it to do anything, and then the MS XP vanilla error came up again and it shutdown WD. I restarted WD, went back into webcam setup and was able to get the capture started again.
Not sure if this is part of the other problem that others are indicating but at the time I couldn’t get into see the error log as by that time XP was attempting to shutdown WD-which is did. What is the file name and location of the raw error log file?
still ok for me…
i was really hoping this component would be stable and OK…
the file is programerrorlog.txt
i have not hooked in the error codes from the web cam component…but I will do that in the next version
what frequency of file update do you have?
Yes, I’ve noticed it must be a very busy day for ya after checking the problem reports.
Frequency is every 10 minutes…
Here’s the cut from that log file:
Web cam capture error Access violation at address 0059A8EC in module ‘WeatherD.exe’. Read of address 00000000
ERROR: Cannot create file D:\wdisplay\webfiles\forecasticonstation.gif at time/date 1:12:00 AM 09/08/04
ERROR: Cannot create file D:\wdisplay\webfiles\forecasticonstation.gif at time/date 2:12:00 AM 09/08/04
Web cam capture error Access violation at address 00944B4C in module ‘WeatherD.exe’. Read of address 00000000
Web cam capture error Access violation at address 009415B8 in module ‘WeatherD.exe’. Read of address 00000000
ERROR: No capture driver selected at time/date 8:28:32 AM 09/08/04
ERROR: Access violation at address 05AE9400. Read of address 05AE9400 at time/date 8:29:39 AM 09/08/04
ERROR: Access violation at address E228FFFF. Read of address E228FFFF at time/date 8:29:42 AM 09/08/04
ERROR: Access violation at address 5ACF4F08 in module ‘vfwwdm32.dll’. Read of address 2401092D at time/date 8:29:46 AM 09/08/04
Resetting rain daily value , day: 9
Resetting wind/temperature daily value , day: 9
ERROR: Access violation at address 06D4795D. Read of address 06D4795D at time/date 2:13:41 AM 09/09/04
ERROR: Access violation at address 06D50F70. Read of address 06D50F70 at time/date 2:13:50 AM 09/09/04
ERROR: Access violation at address 06D50F70. Read of address 06D50F70 at time/date 2:13:55 AM 09/09/04
Resetting rain daily value , day: 10
Resetting wind/temperature daily value , day: 10
the latest beta version has a patch for delphi that looks to fix some memory access errors
and it also has a new debugger added, which captures errors…and click on more details, then email me what is shown there (actualy i get it to automaticly email me even!)
