Hi Brian.
Uploading noaa files fine now Thanks alot Brian.
Some minor issue now after this update:
I upload a snow file customtexout.txt to a diferent folder: public/weather28/ws_snow using wd general ftp function.
This file is now only uploaded to root and not to ws_snow folder any more.
See photo.
Not a big deal as i can change the path in the php snow script to root.
But seems like if needed uploading to different folder in this wd general tab, its not working anymore.
Culd this be a roul of SFTPing, like only upload to root? just wonder.
SFTP (SSH) is tricky when it comes to changing the remote directory from original
it will work as long as you set the new remote directory correctly (i.e think relative paths)
Hi Brian.
Can you give an exemple as to what a “relative paths” is? whit or without the / or: public/weather28/ws_snow or weather28/ws_snow
Thanks for helping
it needs to be a full path (include hidden root paths etc) and with / at the start and end (you might have to experiment)
if its wrong then you get the error, which shows the path doubled up
I did manage to get this to to work (where I had set a file to uploaded to a different directory) on Niko’s SSH server after experimenting
Most of the servers I have used over the years. You could have a dedicated FTP user for different folders. Like user GR3 is set to go to the GR3 folder. The user WD drops files in to the root folder. And user Wasp2 goes into the wasp2 folder.
Doing it this way. I can keep track who’s on first.
Real time Clientraw FTP, vers 4.8 #2
Running here now Brian, seems werry stabil and all files uploading using SFTP.
No error in ftprealtimelog2.txt
Only when you set update freqvens, for me 5 sec, its dissapearing back to zero next time you go into this realtime client tab in wd. its uploading 5sec but shows zero.
Also Brian if possible to make som differences on the icon in taskbar (maybe a 2 number on it, or different colour would be nice :-)) so you can see the diffrenc on main realftp and realftp2?? just an idea. the icons are as now same same.
Nice Brian, updated to latest WD. New Icon reg Real time Clientraw FTP, vers 4.9 #2 looking good
Also see you ad rename files in case of use i can not use this on my host, wd Working fine on SFTP now.
