New user, cron-job, high-lows, extra-sensors
You don’t seem to be running the cron job?
What’s the cron job?
How did you add the water temperature? I have a sensor in my pond that is submitted by Meteobridge but the standard tiles have no option to select that sensor…
See https://pwsdashboard.com/documentation2012/11_cron.pdf. Its why your small blocks have zeros and your history file doesn’t exist.
Jim
I split these post from another very large topic to make answering ans asking questions easier.
You should use an extra upload-file.
But first check your settings as you selected already two extra upload-files, but those are very old.
This is your current weather-data
http://wassmer.org/pwsWD/PWS_listdata.php
That data is upload/used from three files:
[loaded_from] => /is/htdocs/wp11036828_FN9SC3KI0M/www/pwsWD/realtime.txt
./ecowitt/ecco_lcl.arr
./demodata/extra_sensors.txt
You should use one upload file for your Meteobridge as described here:
https://pwsdashboard.com/documentation2012/36_extra_sensors.pdf
Succes
Thanks. I have a extra ecowitt sensor - so do I use the ./ecowitt/ecco_lcl.arr as pathname and file or what else - and how do I specify which extra sensor - I tried the extra temperature/humidity sensor - there is only one extra sensor active.
Thanks - I understand the principle but it does not help me in terms how to get this working. How do I run a cron server on my website or on Meteobridge and where is this set in the template?
Tom
use something like cronjob.org or your host may allow you to setup a cronjob then put the url for the PWS_cron_stationcron.php on your website in it and schedule for every 5 minutes
Hi hcorrin,
Unfortunately, my website host requires me to purchase a SSL certificate for this and it is unreasonably expensive. I will give cron-job.org a try and report back.
Tom
Actually used Meteobridge as a http service using URL /pwsWD/PWS_cron_stationcron.php but what goes into success?
Seems to work. Thanks, everybody. Now I only need to get the extra temperature sensor working…
Also succeeded to get the extra sensor online. Would like to only have the active sensor showing not all 8 though. Also can they be renamed?
Thanks, Tom
The scripts will only process data they receive in the upload files…
Currently your ./extra.txt file has a lot of possible sensors with data, albeit most of them show ‘- -’
If you want / plan to process only one or a few sensors, delete all unneeded lines.
And set the lines you maybe use later to comment by adding a # on the first position.
Make those changes in the file you use as the template file in your Meteobridge.
It could look like this example
# meteobridge extra tags
|actTime|unix|[epoch]|!
|fromtemp|uom|C|!
#|extra_hum1|hum|[th1hum-act.0:--]|!
#|extra_hum2|hum|[th2hum-act.0:--]|!
#|extra_tmp1|temp|[th1temp-act.1:--]|!
|extra_tmp2|temp|[th2temp-act.1:--]|!
|pm25_crnt1|text|[air0pm-act.1:--]|!
|pm25_crnt2|text|[air1pm-act.1:--]|!
|pm25_crnt3|text|[air2pm-act.1:--]|!
It shows 1 active temp sensor which value would be in your weather-data as
$weather[‘extra_tmp2’] => 41.4
There are also 3 PM sensors pm25_crnt1 pm25_crnt2 and pm25_crnt3 which have values in your extra data.txt. The show up in your weather-data as
$weather[‘pm25_crnt1’] => 7.0
$weather[‘pm25_crnt2’] => 7.0
$weather[‘pm25_crnt3’] => 6.0
Hi Tom,
If you use Meterbridge upload (realtime.txt) as your primary data-source, you can only use the extra ecowitt upload file for lightning and AirQuality sensors.
One uses that if they have a f.i. a Davis station as their main weather-station and some extra sensors from an ecowitt-station.
Those users with a “full” ecowitt-weather-station upload the complete data directly (custom upload) bypassing a Meteobridge.
Question: What is your weather-station configuration currently?
Thanks Wim. Now I would like to rename the block name and the sensor name into pond temperature - and ideally make it smaller - or even better adding a icon logo for water temperature as in the template I asked about above.
Block titles are in PWS_blocks.php, and you can change the sensor name in extra_temp_block.php. I suspect you could have found this answer quicker with a forum search. . .
Whose template?
It was in a thread of the map of template users. I cannot find the post right now, but it was a water drop showing. Yes, I read through the tutorials, but it warned me to change anything in the PHP files - or to save with a different name and add the file name to an extra.txt page that I do not have and do not know what the syntax of such a post would be. That is why I asked. So, I will change those two PHP files and save them under the original name. I hope all works well.
Thanks, Tom
Sorry, I’ve been changing files for too long :roll_eyes:
You could use the lang-en.txt file to do the changes for your language only. . . I think this is probably recommended.
So, for block title add an entry
|Extra block large|Pond Temperature|
Thanks - that worked but how do I change the Extra block large title of the block. I did it in the PHP file but it seems not in the correct place…
Thanks again! Tom
I think I was still editing a post when you replied. Try the lang_en.txt method in post 17.
Where did you do it?
All good now - it seems that I replaced the edited from the server instead of the other way around. Thanks so much!
