Need bit of help with clientraw.txt location ** solved **
been setting up the PWS dashboard.
in the setup page
Live data file we will use
./clientraw.txt
Is not working for me. #-o
https://www.weather-above.com/pwsWD/index.php
https://www.weather-above.com/clientraw.txt
Thank you
It appears it is in your web root.
try …/clientraw.txt
As @blainec said you should change in easyweathersetup the location to …/clientraw.txt
You can always check the location and contents of your clientraw.txt
=> Module test PWS_Dashboard => left-second button with the current link “/clientraw.txt”
All files are listed in the dropdown, the “realtime” data file, as set in easyweather, is always the first one
The meaning of the the relative addressing part:
./ => same folder as the starting script => in this case pwsWD
/ => the root of your providers or your webserver, never use that one
…/ => 1 folder below the starting script => weather-above.com/ => this is were your clientraw exists.
It’s working
Thank you all for your help much appreciated sometimes my dyslexia get the better of me
:smiley:
