MySQL Question
Hello,
I have been populating my MySQL database for a while now and am beginning to look into actually doing something with that information. I have installed JPGraph and am working on doing some realtime graphing. However, I am running into a problem with the data and time fields. Mainly that most PHP functions rely on having the UNIX timestamp to create a time format and the time field in the database doesn’t even show am/pm, much less having a simgle timestamp field. Without tha am/pm indicator, I can even use the separate date and time fields to create a single timestamp value.
I see that the station_id and station_name usually contain the time including the am/pm indicator, but they are both prefaced by a dash ‘-’, making these fields dificult to use. Has anyone else figured out an easy way to calculate a single timestamp value for each data row?
Here’s whats in my db:
mysql> select date,time,year,hour, minute, day, month from wx_data
→ where month =‘12’ and day = ‘28’ and time > ‘13:30:00’;
| date | time | year | hour | minute | day | month |
| 2004-12-28 | 13:31:00 | 2004 | 13 | 29 | 28 | 12 |
| 2004-12-28 | 13:32:00 | 2004 | 13 | 30 | 28 | 12 |
| 2004-12-28 | 13:33:00 | 2004 | 13 | 31 | 28 | 12 |
| 2004-12-28 | 13:34:00 | 2004 | 13 | 32 | 28 | 12 |
| 2004-12-28 | 13:35:00 | 2004 | 13 | 33 | 28 | 12 |
| 2004-12-28 | 13:36:00 | 2004 | 13 | 34 | 28 | 12 |
| 2004-12-28 | 13:37:00 | 2004 | 13 | 35 | 28 | 12 |
| 2004-12-28 | 13:38:00 | 2004 | 13 | 36 | 28 | 12 |
| 2004-12-28 | 13:39:00 | 2004 | 13 | 37 | 28 | 12 |
| 2004-12-28 | 13:40:00 | 2004 | 13 | 38 | 28 | 12 |
10 rows in set (14.62 sec)
Would using 24hr format help your situation?
I am interested in doing something with my data as well so your project interests me.
How do you like JPGraph? I need to find a graphing program that will run under Mandrake.
Ok,
First, I completely missed those separate day, month, year, etc fields. So using those I was able to create an expression that would give me the data I needed. I also found that when you import the INF data file, the time is in 24 hour format. Go figure.
I through together a quick page pulling from many different tutorials which shows the temperature graph for a given date. The code for the page follows:
<?php
include ("./jpgraph/jpgraph.php");
include ("./jpgraph/jpgraph_line.php");
function TimeCallback($aVal) {
    return Date('H:i:s',$aVal);
$db = mysql_connect("server","user","password") or die(mysql_error());
mysql_select_db("Weather",$db) or die(mysql_error());
$sql = mysql_query("SELECT * FROM wx_data WHERE date='2004-11-30'") or die(mysql_error());
while($row = mysql_fetch_array($sql))
$outtemp[] = ($row[6]*9/5)+32;
$timestamp[] = (strtotime(sprintf("%04d/%02d/%02d %02d:%02d:%02d",$row[39],$row[38],$row[37],$row[31],$row[32],$row[33])));
$n = count($timestamp);
$graph = new Graph(800,600,"auto");
$graph->SetScale("intlin",0,0,$timestamp[0],$timestamp[$n-1]);
$graph->img->SetMargin(50,20,10,70);
$graph->title->Set('Date: '.date('Y-m-d',$timestamp[0]));
$graph->xaxis->SetTextTickInterval(10,0);
$graph->xaxis->SetLabelFormatCallback('TimeCallback');
$graph->xaxis->SetLabelAngle(90);
$tempplot = new LinePlot($outtemp,$timestamp);
$tempplot->SetFillColor("lightgreen");
$graph->Add($tempplot);
$graph->Stroke();
You can find the results at http://weather.musaland.com/graph.php
Now I just need to figure out how to make a form produce this page so I can pick what is plotted and for what date range. Should be relatively straight forward though.
check this thread out too
to help you in your work :slight_smile:
Thanks, this helps out a bunch.
Looks good. I am going to try perl/tk and see what kind of trouble I can get into…
keep us updated on the combination of work done…it would be great to be able to share the scripts :slight_smile:
Not sure if this is the right thread to ask, but would there be any chance of a separate forum for using MySQL with WD? I’m just starting to work with the MySQL side of things and it would be nice to have a place to swap SQL statements, ideas etc.
It might also be relevant to include PHP in this as well - I think most people are using it and there are already some useful PHP snippets floating around here.
The ‘Creating Weather Web Sites’ http://discourse.weather-watch.com/c/23 board is fairly quiet and reasonably well suited to this kind of discussion. If the amount of MySQL or PHP discussion gets too much in there then I can always create a child board for specific tools.
