MYSQL Data Import 10.15z
Brian
This is much better. I can even run it on two machines at the same time to the same database, fantastic
But I have a horrible feeling that importing all my old data is going to be impossible.
In feb of this year was there a change to the date format in the .inf file ? dates are being imported 03/11/2004 and 29/04/2004. Till it errors out with date error. Or was it a change in windows ? I think I went to XP around that time
Also some files do not have the station name, this should be easy to fix with a script
Cheers
Keith
you could check the date/change the date in the corresponding wd text log file, then do the convert log file to graph file
the station name is derived from the clientraw.txt file
yes, if you copied the datafiles (and the same directory structure and the wdisplayftp.reg file) to a another pc, then you can do the udating from that pc…
Will do
keith
