Move to new computer
Hi All,
I have just moved WD to a new computer. :smiley: :smiley: No problem with the move, I found the old posts on how to do it. My problem is getting the new computer to read the data from the WS3600. I am using a USB to COM plug that seems to be working. I canโ€™t get WD to read with fetch3600.
Any thoughts???
John
Running XP WD 1037jb03
WD is set to use COM 5
make sure the open3600.conf file is set for the correct com port
also, USB to serial adaptors and fetch3600 are not a good mix (because the 3600 station uses non standard communication)
straight serial is best
