More than one weatherstation
The possibillity to connect more than one weatherstation and then choose what data to use from what station.
what you can do is run a completly separate version of wd…connected to another weather station,…if you have a spare com port (e.g a usb com port?)…using the file you created called 2wd.txt in that directory, but i guess that not exactly what you mean?
have you seen that you can add dallas 1 wire temp temp/hum sensors and even a lightning counter or solar sensor to any weather station?
(using either the dallas serial port adaptor (there is a usb one) or a labjack (which is USB)
What I had in mind was the possibillity to graduly change to a new station.
I
why a ws2500?
the data only updates every 15 minutes 8O
What is the best station to buy then?? (in your oppinion)
When I go for a new station, I might as well go for the best :smiley:
a davis VP :slight_smile:
yes, you only live once!!
OK, then I have to begin collecting emty bottles or something.
You don
you could add a solar sensor to your ws2310 …using a 1 wire solar sensor…and add using a 1 wire adpaptor and a labjack…would be cheaper than a new station
About the Vantage Pro, how reliable is thw wireless and does it live up to the range they say.
I live in the city and it is rather hard to set up the different instruments so that they give a correct reading :? therefore I don
