Month End - Daily Report for 0 :10 :2004
I had major problems at month end which were cleared by moving to WD 10.18c.
A remaining problem at month end is that in the Daily Report page for October produced overnight, see http://www.cuckney.pwp.blueyonder.co.uk/weather/October2004.htm, the final day, 31 October, has the link to its 24hr graph set as ‘Click here for todays 24 hour graph :0 :10 :2004’ with link set to look for 20041000.gif.
The correct daily image 20041031.gif has been automatically FTP’d to web server.
Is this a known problem fixed in later release?
JohnC
good the end of the month problem is fixed
but, yes, thats still a bug
see mine:
http://www.weather-display.com/windy/gb/October2004.htm
too
but, i see the link tot eh daily web cam image is OK
so i just need to compare what i did there
you can manulay edit the October2004.htm file in the web files folder and then re upload it, to fix this
Windy
Thanks - I left the page so that you could see the actual situation.
I will update the page now.
JohnC
Hi Brian
The end of month report for October 2004 list.
Rainfall for month was also 0.0 mm should be 113.2 mm
Maximum rain per minute 0.0 mm on day 00
Maximum pressure 1027.4 mb on day 00
I have manually corrected the data for end of month report.
DonM
i have now fixed the link to the daily graph problem
looking into the day 0 issue for the last day
