For nearly 2 months I’m using WDL (updated today to version 2.05) together with WeatherDisplay (updated to 10.18d). First month: no problems. Since the beginning of October I’m not able to get all the records in WDL updated. September is still the actual month and all the new records (all well presented in WD 10.18d!) are not published in WDL!
What is the problem and is anyone able to solve this?
Please, take a look on http://www.xs4all.nl/~bleekerk and ‘click here to enlarge live dashboard’.
are you refereing to this months all time records?
i just checked my WDL and its OK
did you set the url location for the clientrawextra.txt in the wdl config file (and the clientraw.txt)
Yes, must be OK: checked and double checked. The ‘actual’ month in the records pop-up window is still September. In the year- and all time records overviews, the latest announcements are registered in September, while the actual latest records are written down today, as I can see in WeatherDisplay…
the numbers in that file are only for the 9th september
check the file create date/time on that file
and check for any other occurences of that clientrawextra file
the clientrawrealtimeftp.exe
uploads that file (every 10 minutes) auto
but make sure you are using the latest version of that program by downloading and intalling the full version of WD, and getting that file overwritten (you need to exit it first)
yes, sometimes its a good idea to let the full installer update running associated WD .exe programs so that they get updated (and exit them first)
you are not the only one to have not done that enough 8O
