In temp_c_block, when using ecco_lcl at line 284 “humidy_trend” = ‘n/a’
at 285 the value $weather[“humidity_trend”] evaluates as > 0 and the block always shows an up arrow regardsless of actual trend rather falling through to $arrow=’ ’
There should be two or three = in the first “if” line = means set the value on the left to the value on the right, which is always true, so always no arrow
“==” or “===” compares left item with right item and there will be no arrow, only if the value in the field equals to “n/a”
{ if ( $weather["humidity_trend"] == 'n/a'){ $arrow = '';}
Thanks for spotting this,
Will be in an update but in two weeks as there were other requests for that block also which need to be tested.
