Minor dutch language bugs in WDL3.01
Dear,
  • the winddial (east E should be translated to O (oost))
  • the error in neerslag per uur is solved, but you forgot to translate rainfall last 7 days & 30days :wink:
  • the weather remarks are in english, while you translated all the rest in perfect dutch (thx) could this be solved
greetz
winddial I can amend,
I may be still waiting for translations for the rainfall graphs - can you provide them?
the current conditions come from WD. If you can provide Brian with the translations then I’m sure he can incorporate them.
Julian
you can set your own language for the weather conditons in wd
see under setup,control panel, summary image and icon setup, set names for riain thresholds
also, having O as E
surely people will still know what E is?
Dear all,
I changed the weather remarks to dutch as recommended by windy (via WD control pannel)
thx, works fine!
but the rest I changed it already, rainfall is 2 times translated (neersalg)
but you just forgot to translate also the 7 days and 30days rainfall in the graph frop down menu
and that , I can’t change, its programmed in de wdlv3_01.swf file …
The same with temperature last 30days (should be temperatuur afgelopen 30 dagen
Everywhere in the drop down menu you’ve forgotten to translate
