Mind of it,s own
Hi Gang, I am running the latest version of “Weather Display” and within a period of 12 hours it tries to start up the rainwise data logger ( screen comes up) this halts WD, my PC is 600MHz Pentium 3, 512mg ram, and resources run at about 56% free, I have a couple of small programs running , IE UI-View, Windmill, anybody have a cure for this ??
I am running WD with the campbell setup and using a CSV file from Windmill software.
there are a 2 weather station type setups where this is occuring with
the cambell and environdata
now, i have actualy done a test, via a direct feed from a envriondata station in another country via a TCP feed
and it happened to me too
now, the only way it can happen is that if a data flag (boolean) or station type are being set all by themselves!
(it might be some memory location being overwitten)?
i have put in a double check for the correct station type
but I have another double check i can put in place too, and I will do , and upload 10.18g now
i am very confident i have found and fixed this
it was a pointer to ann array that was not being reset each minute, with this and a few other weather station types
uploading 10.18i now to fix it
