I am attempting to set up my mesomap. I have gotten the image and have setup the desired url’s, APRS stations, etc… However, I now have a couple of problems that I would greatly appreciate some worldly advice on.
- When I update the data (update now button) the values are a bit skewed such as the temperature is 144 degrees, barometer is off the chart by about 8 decimal points, humidy is 143% (rather humid), and so on.
- When I go into setup/mesomap/position stations, it shows all of the station locations that I have set up but only shows the data from the first station in the list. This is also the case when I display the mesomap under the “view” tab or from the right hand mouse button when positioned over the realtime graphs.
Any ideas, suggestions, or even snide ridicule would be appreciated at this point!
