Memory Leak ? (2)
Hi I noticed this about every hour that the memory level has dropped form 170mb down to 40/30 and even down to 20mb. I hit free memory now it goes back to normal (150mb or so). Im down to 40mb again :slight_smile:
No programs of mine are being denied so thats a good start. Im wondering if anyone else is having this problem ?
Brian and I gave been working on this for a while now. There was an issue with the speec option that Brian seems to have fixed now. Make sure your running WD 9.60 for this fix or disable the speech option. This has made the leakage much better.
Bob
Not any more! Just added 512 megs of SDRAM for $60 bucks.
Tom
Bob
Okay I turned off the speeches and ill see what it does. Yep running 9.60version. I have 258mb of ram.
Hmm, well I turned off the speeched and im already down to 50mb and it was up to 173megs a few hours ago 8O.
Bob
Hello,
Even with this version WD still use 54Mb of memory, which is more than window himself… Strange isn’t it?
WD is a big memory consumer… Would it be possible to find why??
H
On XP Pro SP!, 12 megs in staionaless mode and 26 megs in Dallas 1-wire. You guys must be running some other stuff.
Tom
Hey Brian,
I don’t know what you done with v960, but the mem useage is less than half on my system now. Now running 11,156K after 14 hours.
Good job. :wink:
Steve
