McMahon ECMWF 2025022606 z Missing - Last was 2025022600 z
McMahon - Last Good ECMWF was ( 2025022600 z ) and Last Should Be ( 2025022606 z )
Note: this was Checked at 2025-02-26 14:00 UTC.
It is possible that the Data was running Late and may now be available.
Kindest Regards,
Tony
Server that runs the ECMWF scripts is up. The database servers are all up and running and there aren’t any problems with undeleted records. I’ve restarted the scripts and there aren’t any errors showing.
Still checking, but I’m assuming the ECMWF data is late for some reason.
As I was checking servers out I took the opportunity to update and reboot all six of them. I don’t know whether the rebooting fixed the problem or if it just corresponded with something else fixing itself, but the 06z ECMWF run has started and looks to be working correctly.
06z data for 26/02/25 is now available.
