McMahon ECMWF 2024061406 z Missing - Last was 2024061400 z
McMahon - Last Good ECMWF was ( 2024061400 z ) and Last Should Be ( 2024061406 z )
Note: this was Checked at 2024-06-14 15:00 UTC.
It is possible that the Data was running Late and may now be available.
Kindest Regards,
Tony
This was the same problem that affected the GFS 06z run. It’s a file permission problem. I’m not sure why the problem has suddenly arisen after a week or more of no issue, but I’m hoping I’ve corrected the problem.
I think one problem I’m suffering with is lack of disk space. I’ve moved from servers that had 7TB of RAID1 storage to servers that have 160GB of storage. In the past I could have extra copies of data sitting around ‘just in case’ whch clearly isn’t appropriate when there’s less space available. For example, I was able to keep 2 days worth of GFS and ECMWF data source files online, but at tens of GB of data that’s not a good thing to do on the new servers…I have already cut the download storage back!
I’ve got a couple of ideas of how to reduce storage requirements even further, so I’ll be looking at implementing those in the next couple of days.
PS. 12z ECMWF data is now available (a bit late) but the status file updated correctly this time.
