McMahon - Last Good ECMWF was ( 2023111900 z ) and Last Should Be ( 2023111800 z )
Note: this was Checked at 2023-11-19 08:20 UTC.
It is possible that the Data was running Late and may now be available.
Kindest Regards,
Tony
Incorrect was issue with new script.
Hopefully not a long night for me correcting.
I hope it’s an easy fix. I had a couple to make myself yesterday.
Yep, Hopefully I have done it, Simple error on my part I think, just tested and all good.
So hopefully correct from now. Sorry about that.
It was a +3 +6 +12 switch I had in the code which I did not think would impact the newly recoded +8, but it did.
To explain, the original switch was due to running one script for GFS/ECMWF and ECMWF being available later than GFS, I forgot to remove it.
Hopefully that makes sense.
Kindest Regards,
Tony
It makes sense. I also discovered a bit of code yesterday that was no longer serving any purpose. Luckily it was just writing a file that was no longer needed so other than consuming a few cycles of CPU it wasn’t doing any harm.
