McMahon - Last Good ECMWF was ( 2023111706 z ) and Last Should Be ( 2023111712 z )
Note: this was Checked at 2023-11-17 21:06 UTC.
It is possible that the Data was running Late and may now be available.
Kindest Regards,
Tony
Data is available for download, but the report file hasn’t been updated. I’ll update it manually and then investigate why this has happened.
Cheers Chris,
Well that caught me by surprise, Was flat out coding other stuff and that popped up.
Glad the new checks flagged it though.
Data only shows
Fcast_hr, prmsl, apcp, wspd, wdir, hgt1000, hgt500, tmp2m, tmp925, tmp850, tmp700, rh1000, rh925, rh850, rh700, rh500, rh300
2023-11-17-12
and ADV
Line elements : Fcast_hr, tmp, rh1000, wspd, wdir
+ve latitudes are North. +ve longitudes are West.
Lat=-52 Long=-159 HGT1000=
2023-11-17-12
No actual Data below those lines.
I missed a command out of the new streamlined download script that has a shorter delay between retries. The dev system doesn’t make the report file available via the web so I didn’t notice I’d missed adding it into the new script. It’s added now so it should be good for the 18Z (when I’m hoping to be fast asleep!)
Confirmed. I’m investigating.
I think it was a typo in the config file when I moved the new scripts over. I had to add a number of new entries to the config file so copied these from DEV and then edited them to suit PROD. I think my finger slipped in an extra DEL key on one entry.
The 12Z run is re-running now and is about 25% complete.
12Z re-run is complete and the web interface is providing valid data again. Apologies for the outage.
