Maximum Temp Is Way Off
My maximum daily temperature in WD has started acting strangely. While using v9.55 I noticed that there was at least a 20 degree difference from what I had seen on the Davis WM II during the day, & what WD showed later the same day as the high.
Same thing happening with v9.72a. Everything else seems normal & I haven’t changed anything with either the computer or the Davis.
Using XP, 800mhz Celeron
Any ideas please? This is the one little reading I always check first so I really miss it!
hi…where abouts in wd are the daily hi’s you are refereing to excatly?
thanks!
ah, so its not being updated with new readings?
strange!
