manual input cloudiness
would it be possible, having the option for manual input of cloudiness (0 - 9; 9 = “sky not visible”), which is also taken over into the synop code?
Attention: if there is no manual input since the last synop output, there should be a / . (how it is printed at the moment)?
fine would be having a small popup window for input caracters 0-9…
would it also possible having a custom setup (hum & temp) for the thresold “haze”(like the fog setup)?
Cheers
i will do the haze settings today…all going well…
and also look at this cloudiness…maybe put it in the input daily weather?
Hi Brian, you are great! :smiley:
please make it simply as possible, so that also my mum could do the input of cloudiness… (and she is indeed not an expert on computers …)
is then there also a customtag availible for cloudiness?
I am so sorry, about the bad healtness of your dad … I read about that one hour ago in an posting here … :frowning:
cheers
10.13w has the haze setting in the summary image and icon setup now
but then the wife locked the computer room door, and i had to do an hours housework…
so i will the cloudiness thing later now
have you done your housework yet and did you find some time for the cloudiness thing? :wink:
Cheers
