Main Screen Graphs
The main screen graphs are not auto updating,if you restart program then the info shows up but does not continue to auto update. This happened with 9.89 and 9.89a.
win98,wm-918
Emilio
Same here with 9.89a.
WinXP
LaCrosse 2310
I just noticed this as well. The graph stopped at midnight last night and only moves when WD is restarted.
I also found that you can move the baro line up or down and it will update, better than restart.
Just downloaded 9.89b (labeled on main screen as 9.89A) and it’s not updating either.
Went back to 9.88c and all is well. :slight_smile:
John
89c is O.K. here
carl
I noticed the same problem with 9.89a !
apologies for that glitch
9.89c fixes that
Brian fixed the graph! Isn
