i know i have not fixed the individual email thing…
and i have been meaning to fix that (its not working quite right, yes?)
so your request would need to be added to that system somehow?
Hi Mikeymoon
I have finally sat down and tested the email to each email custom each weather report
and i found what was wrong, and have tested, and fixed
the test was to set a time for a email address, by clicking on that email, then setting the time in the time setup above, and turning on the times for each file switch, then turn on the custom weather report switch
then click on ok, and then go back (i will fix this for the next version), then turn on the custom report for each email switch
BUT and use this ftp version: http://www.weather-display.com/downloadfiles/ftpupd.zip
and unzip to where you have WD installed
( i will upload a new 10.12z beta now with this latest ftpupd.exe program included in it)
anyway, i tested, and it works
so, now , you can send a customised weather report to each email and at different times too
great!
sorry it took me so long to have a look at this
it was actualy only a simple mistake, and easy to fix
the times of each email cannot be deleted, even if you delete the user.It passes to the new user.
The week days does not work, if you change it, the changes is applied to all the emails on the list.
If you turn the swich for each e-mail “on” only sends to the first e-mail on the list for each e-mail ,not the others , also sends only to the first e-mail by subject line.
This all happens when the swich by each e-mail is “on”.
please email me your settings file, and i will see to fix it
thanks
(go action, back up registry entry, then email me the file wdiusplayftp.reg from the folder databackup
thanks
actualy, i think i have found something
please try this ftp version:
(unzip to where you have wd installed ) and let me know
(but also though email me your settings still) http://www.weather-display.com/downloadfiles/ftpupd.zip
(vers 7.26)
