Hi Brian, WD MacB242 will not exit, Having to do a force quit to exit. This is what was in the programerrorlog.txt (Screenshot & file)
BTrip
programerrorlog.txt (1.05 KB)
BTrip
I did notice that exit error myself
(using the red ‘led’ top left of the window does work)
I will see if I can fix
Hi Brian, here is a screen shot of the programerrorlog.txt from today. WD-Macb242 is still running. There is a Access violation. Hope this helps
BTrip
not really sure at this stage what is causing that error
interestingly it occured every few seconds one after another, which means it could have been something that updates frequently (e.g clientraw.txt or customclientraw.txtor similar)
Hi Brian the error occured every few seconds one after another is from yesterday when I try to shutdown WD
BTrip
Hi Brian programerrorlog screen Shot after trying to shutdown WD.
BTrip
programerrorlog.txt (2.3 KB)
yes, as I mentioned, i will try and track down and fix that exit error
Hi Brian exit is working on WD MacB242 Version on 1 September 2015 - 11:11:20
Thanks Again
BTrip
Problem with data collection.
After several days of successful running, WD last night lost about 7hrs of data. You can see this in the attached snippet where the times on the graph jump.
This is version 242 on Yosemite.
Dave
was WD running during that time?
if so was there any errors under view, program event log?
Yes, it was running the whole time.
I went to View Panel → Data log file and it hung with 100% CPU.
Had to force quit and restart.
Went to “View Panel → Program event file” and it is empty (perhaps because of the restart).
Next time, will go straight t the Program event file.
There was nothing in the System Log.
Ceers,
Dave
I would like to make the screen bigger. Currently I have it set to 1.5. Since you can’t customise the display is it possible to add a screen size of 1.75x as 2x is too big and 1.5x is too small
Also have you had a look into the reason why i am getting unusual spikes when i am plot UV on the graph?
These are the spikes I’m talking about.
Also thought I would take a chance to ask whether there are any advancements on the downloading of historical data on the WMR200
With regard to the scale getting squashed up combined with missing data, this happened again and there was nothing in the log about it. However, some time in that period the data count went back to zero. It had got up over 50,000 so maybe something happens when it reaches some “magic” number like 65,000 and goes back to zero?
Dave
Hi Brian WD MacB242 shutdown on its own @ 12:00 noon, this was in the programerrorlog I have also attached the log. Hope this is helpful.
Btrip
Access violation at address 002526E7, accessing address 0000020C
Above error or program log occured at :12 00 01 09/06/2015
programerrorlog.txt (4.32 KB)
that noon error could be with the fireweather index, which is updated at that time
@doggy
sounds like an error was occuring preventing WD from updating the graph data files, hence the squashed appearance
@mdheron
so that uv value in the spikes on the graph I take it is not correct?
latest update imroves the reporting windows
Latest update installed.
Note that going to view panel → data log file hangs the program every (5 in a row) time
Dave
They are not correct. It appears to be something connected with outdoor and indoor temps
I’ll keep an eye on it and let you know what happens.
Update: They are still occurring with the latest update but I did notice that they appear to only occur when there is no reading from the UV sensor
HiBrian, lost another 4hrs of data this afternoon.
Access violation at address 000184D4, accessing address FFFFFFFB
was in the WD log.
Machine was not busy at the time (doing almost nothing but WD) plus I had re-niced the WD process to be one of the highest priority programs on the system. I imagine the access violation is related.
Regds,
Dave
