Long number bunching graph
i thought i posted this early this morning but it is not list so i’ll try again
there is a long number against the sunhours et graph that is playing havoc with the layout see below
i think this problem been seen before
I appear to be the only one with this problem
now running 10.20q on both units using wmr 928 or 918 consoles
as it is the left scale with the long number it is ET related problem
is any boby else with a wmr 928/968/918 having the same problem with solor hour in veiw panel
I’ve seen this before on more than one WD graph. It’s a result of software doing floating point math. Sometimes a number that should be zero ends up represented by a very small number in scientific notation. I don’t think it can be avoided without the programmer specifically checking for this condition and forcing the result to zero.
I’ve seen results like this in Excel spreadsheet calculations occasionallly, too.
This isn’t related to the version of WD you are using or the make of your weather station.
You are not the only one seeing this, it happens to me to and I run a Davis VP! Sounds like it is a calculation result problem, but it would be nice if Brian could fix it some how.
This problem also manifests itself in the weekrep.htm page on the last 7 days rainfall graph (raindetail.gif), at least it does for me. Take a look at http://www.broadstairs.org/weekrep.htm
Hi broadstairs
just checked your link interesting the value on your rain chart is the same as i am now getting on my sunshine hour they should be 0 (zero)
After Christmas Brian can you look into this for use
Happy Christmas to All
its a graphing component i have used,…so I have no control over that…
but there is an updated version, so I will look into that to see if that improves it
i await the outcome
Merry Christmas
i have this fixed now
I found I could force a start and end value for the left hand axis
uploading a new 10.20y now…
I am running 10.20y now and just forced an update of ave/extremes page. Please take a look at http://www.broadstairs.org/raindetail.gif. I think we have a problem on the right hand axis as well.
oh
i do not have that issue, as I use mm (metric)
i will see if i can duplicate and apply the same fix
i have duplicated and now fixed
will upload a fresh version
Brian I still seem to have a problem with http://www.broadstairs.org/raindetail.gif, dont know if you might have already fixed it as I am still on 10.20z.
yes, i have fixed that in the latest version
Brian I went to 10.21t this morning and this problem is back again. Please see http://www.broadstairs.org/weekrep.htm on the rainfall graph at the bottom.
when is your raindetail.gif uploaded
which version were you using at the time of the upload
example if uploaded at 00:10 then it would be version 10.21r
if you loaded 10.21t after upload then see if it happens at next upload
is it ok when viewing the rain chart in the view menu
The gif file was created this morning on 10.21t, I shut down over night so have to manually create and upload these things! So the bad file was created and uploaded by 10.21t. It is also bad on the view version of the chart!
