Log file and upload to underground is not correct
I installed 9.39b for the first time and started testing upload to underground weather and notice the outside temp that displays on my screen is not the same that is being sent and also not correct in the daily log file also. example is my current outside temp is 47.3 but the log shows 48.9 also is what underground weather is showing.
This is a line from log file
27 12 2002 02 03 48.9 77 42.0 30.277 0 0 270 0.000 0.000 0.000 0.000 48.9
27 12 2002 02 04 48.9 77 42.0 30.277 0 0 270 0.000 0.000 0.000 0.000 48.9
I am new to this software but looks good.
Bob
the log file and wunderground both are the last 1 minute average temperature
hope that helps and accounts for that
what weather station type?
Thanks that makes sense.
I also think that it can be a bug, more hours the program goes working the difference increases, on having restarted the program fixes the problem up. You will see the jump (unreal) that does the temperature after restarting Weather display. The real temperature was 10.2
hi, what weather station type?
hi all,
Can I join this topic ? Look at the middle time jumps one hour ahead
01 01 2003 14 57 3.9 98 3.6 992.0 7 6 180 4.7 0.0 0.0 0.0 3.9
01 01 2003 14 58 3.9 98 3.6 992.0 7 6 180 4.7 0.0 0.0 0.0 3.9
01 01 2003 15 59 4.2 98 3.9 992.0 7 6 158 4.7 0.0 0.0 0.0 4.2
01 01 2003 15 00 4.2 98 3.9 992.0 7 6 158 4.7 0.0 0.0 0.0 4.2
01 01 2003 15 01 4.2 98 3.9 992.0 7 6 158 4.7 0.0 0.0 0.0 4.2
and beside that I have still 2 times several values at my av/ex list and
2 values at the top bar title:
N,6.2 m/s,10,3C,0,0mm,98%
W,0.0m/s, 9,4C,4,0mm,97% (which is the right value)
I have values at sensors 1 2 4 and 8 (4 and 8 doesn’t exists and are disabled sensor names)
but there is reading from 2 sensors since december at vers 9.36
Has anyone same problem ? (WMR900H WinME , but I think it’s the interface to my comport)
Anyway a happy new year to all of you !!!
La Crosse WS2300
Another example, Before and after restarting the program
02 01 2003 12 22 19.1 51 8.8 1010.6 11 17 303 0.0 0.0 36.8 36.8 25.5
02 01 2003 12 23 19.1 52 9.1 1010.6 15 18 292 0.0 0.0 36.8 36.8 25.4
02 01 2003 12 25 18.7 52 8.7 1010.5 9 15 292 0.0 0.0 36.8 36.8 25.6
02 01 2003 12 26 18.7 52 8.6 1010.6 9 12 277 0.0 0.0 36.8 36.8 25.7
ahh
i have done that on purpose, i,.e not update the averages for the first 2 minutes, to allow for the latest readings to have been read in (some weather stations can take a while to get all the readings read in )
i have it now where the initial temperature dsiplay is the last 1 minue average temperature read
Salut!
It has all the aspect of being a bug, Weather display has been showing for more than 10 minutes 16.2
I have notice tonight we are having falling temp. fast and the log file and the underground update is not 1 min average.
You must being using some value from the start of WD and average all temp reading. Because reboot will show the correct temp untill time past and then same problem.
May be this is the way it should work but I would think you would want the latest wihin 1 min loged not an averager over time.
Runing version 9.42b. ws-2310 weather station.
http://home.cfl.rr.com/bobsegal/weather/MyWeather.htm
it might be just for the 2310 staiton type (which I have only recently supported, and still ironing out some quirks)
i will do some investigating
found the bug
i was alloacting the latest reading t position 5 in a 6 number array instead of positon 6
first time start alocates the #6 position, but then that #6 is not allocated anymore…
uploadin a new vers now
i have finally found the real bug
a missing line of data
uploading a new vers, 9.43c, now
sorry about this!
Thanks, I have been verifying and thought that it worked correctly, in any case, thanks to give answer and solution. can I make another question?, why the graph changes every minute and is different from a minute from the other, the even minutes it displays a graph and the uneven minutes other graph, does not have as much importance but it is to me peculiar,
In this side of Europe it seems that it arrives the winter and the snow!
Thanks again for all!
the graph shows even minute data then odd minute data, alternating each minute, as only half of the 12 hour data can be seen at any one time(limited number of data points to plot)
oh and the new vers is ready now
Ver 9.43c has fix the problem now and the data is being stored and sent correctly.
Bob
:grab:
at last
