The localweather.gif picture looks to be getting cropped in width (on the right hand side). In particular the ‘Gust last hour’ line when the direction is something like WNW, half of the last W is missing. Also the oC on the hi and low temp is missing. It might only need another 5 pixels or so.
Just noticed mine is as well… see http://www.broadstairs.org/localweather.gif
will upload a update which will make it a bit wider
Downloaded 10.21a. Its nearly there but no quite. See attached image. The oC is still being cut off the high/low temps.
LOL
ok, i will add a bit more width
Looks good in 10.21e (see post below) - thanks Brian ! =D>
