Hi Wim
Thank you for the lightning module. First strikes today and measured perfect.
Gert
Hi Wim, the lightning module gets displayed in any normal browser, but not in a smartphone view/browser?
Get it displayed on my IPAD, but not on my Iphone X.
Any way to have it also on a smartphone displayed?
Matthias
In the first version, there were no small blocks in “smartphone” or very small mode.
The request was to add at least the warning block (top left) and 1 other important one.
So on a phone you see two small blocks and often the first 1 1/2 larger blocks.
If for you, the lightning block is more important, set exchange it with the “Max. / Min. Temperature” block in your settings.
Dankeschön! Got it…
But as I see, there should be in the future also in the Standard Temperature Panel still enough space to add the Max./Min-temp- time stamps and up/down arrows?
The up- down-arrows replace the words High value and Low value
When translating High Low some languages needed far to much space.
It is a good idea, I think, for the standard temp block to move the high-low values below the temp value
and then below that the times. Will fit nicely
Please add your ideas to the wish-list so that others can comment (and i not forget it).
But you also use up-down arrows for trends. . . I tried sloping arrows ( and
) for trends once but the old Edge did not support them
These should “always” work. https://www.toptal.com/designers/htmlarrows/
And edge uses chromium nowadays, so “not supported” should improve also.
Still a health warning here
And edge uses chromium nowadays, so "not supported" should improve also.
Haven’t tried new Edge, yet, but old Edge displayed sloping arrows on a solid blue rectangle. They looked very strange.
instead of using High and low, would Minimum and /maximum work for the translations? Or, abbreviations such as min. and max?
