I use L2K for my lightning detection. On my web site the map looks fine but on the WDL picture the map is coming out oblong. What size should I set the map picture at.
Set it at 350 x 350 pixels
I set it to 350x350 but the picture still still looks like an egg on its side.
It works good at 640x480.
Ah perhaps I should have explained this more. The 350x350 pixels is only for the nexstorm map. For L2k you can leave the picture as is or you can resize it to 430 x 320 if you wish to save bandwidth. WDL will resize it automatically and as long as the aspect ratio stays the same it should look OK
Julian
After experimenting I found you need to resize the L2K output to a 1.33 to 1 ratio. This gives you a roundish picture instead of an oblong picture.
Also I just want to say WDL is an amazing piece of software.
