Hi Brian
I have two things. 1. If I check Labjack counter under (setup,I have Labjack,view readings) it will say 10, and if I look at WD Lightning count it will say 20. It looks like it doubles the count. 2. I don’t think WD is writing to the lightninglog.txt file, it is always empty. Thanks Joe
ok, i haved added the write to the log file now for the labjack routine, for the next version of wd
not sure why its double counting at this stage, but i did find an intialisation error that i have fixed
Hi Brian
The log files are working and have the right count. Thank You Here is a screen shot of the lightning window, the count on right side with time is right count 24 but total shows 48? The main screen also showes 48? Also the Total since noon always shows 0. I hope this will help.
Thanks Joe
i know the dallas boys have reported the same thing
i have looked before, but could never see anything obvious
i will do another look!
I might also grab the lightning counter from the farm, and hook it into the labjack i now have running with wd here, and so i can have a lightning counter here
i have found the problem
i was allocating the count to the minute array as and when the lightning strike occured,instead of at the change of minute…
uploading a new 10.13k version now
and i have also fixed the count since noon not working with the labjack counter
:lol:
Thanks Brian, Great Service Joe
if you are quick, its available from
http://www.weather-display.com/uploads/beta.exe
now
note, the fix is not retrospecitive though
if this is fixed, then its a fix from an old bug!
Great to see it fixed, Brian !!!
here’s hoping
(as this problem has been around since i added lightning couting)
let me know
did you see leo where you can ftp the clientraw.txt file to another ftp server?
(see in the webfiles /real time ftp setup)
Hi Brian
It work great for me (labjack). Thanks Joe
thats good news
i have been fixing quite a few old bugs lately
Hi Brian
Hope all is well and that everything is going well with the new house. Yes, the lightning counts looks good on the Dallas also. I just installed the new lightning detector today and gave it a check with a gas lighter and the counts look good. I have to get the data grd line connected to earth ground, as you suggested, and see if that will keep me from blowing out the DS9097U’s althought I’m now using the IButton Link now.
Cheers
MikeyM
yes, loving the new house and the fast internet!
but its a dreary dull cold winters day, and gales forecast for later today/tomorrow
Hi Brian
The counter is working good but I found that when I Reset Values the Total Since Noon does not reset. I also found that when I restart WD program ligntning.txt file is cleared of data. Thanks Joe
