Lightning as Big Block *SOLVED*
My site - longsutton-weather.co.uk
After the addition of my Ecowitt WH57 yesterday lightning is now displayed in the upper right small block on my site.
I would like to display this in a large block replacing the current sky block (my nearest airport is 50 miles away and the current sky data is not always accurate!)
Is this (easily) possible?
There is no more lightning information to show, all data fits inside a small block.
So nobody that I am aware of, has developed a large lightning block
You do not need to display a “large” Sky block. Nor a “small” one which is also available.
All blocks are optional.
The last block(s) at the bottom right need not be selected, you can use “none” in easyweather.
Ok - many thanks for your brilliant support
