Brian
I know you probably moved them someplace, but I cannot find the lift/lower temp/dewpoint and lift/lower barometer options. They are not in Graph Setup under the Setup tab. (ver 9.99g) :?:
Keith
Brian
Keith
they were duplicated (but not working in well together)under view, graph history
so they are gone, but i need to put lift/lower indoor temp under view, graph history as well
note: graph setup is not under setup
I’d suggest putting all graph setup and graph related items under
RIGHT CLICKing on the graph. Remove all the non graph related
stuff that is currently on RIGHT CLICK graph.
the items under right mouse click are things are also under view
they are there because it means you can get to them quikly and easily
