Licencing of WD live.
If I have read the readme file correctly the way wd-live is locked to sitename is a bit inconvenient.
At www.hellerupsejlklub.dk (Hellerup yacht club) we hace put up a wheather station.
Our home page is hosted at a provider.
In order access the weather data we have put up a little webserver on hspublic.dyndns.org
What we would like now is (for performance reasons) to place all files (html and flash) except actual data on the main site at provider and only have clientraw and perhaps the xml file on hspublic.dyndns.org and on top of that we would like to have wd-live locked to www.hellerupsejlklub.dk. Is that somehow possible.(The way I read it we would have to register hspublic.dyndns.org which is a bit backward).
PS perhaps I should add that we do not ftp the data to the provider site because that causes problems. Apparently the provider gets a bit stressed by the high numbers of uploads and/or logins and locks out the account after a couple of days(perhaps the uploads are detected as a kind of DOS). Therefore we have shared the webfiles folder via a http server which works great.
That should be fine. The domain you register is where the html and swf files sit. Therefore you would register http://www.hellerupsejlklub.dk
Julian
Actually I’ve just remembered there is going to be a problem with this. Flash won’t let you access data from another domain. This is a built in security restriction with Flash and nothing I can do about it. It means the swf and html files have to sit in the same domain as the clientraw and xml config file.
Julian
