Latitude and longitude?
Hi, I’m having trouble setting my latitude and longitude in sun/moon settings. For some reason it won’t let me type in the numbers?
You set the numbers in the top box on that page (Hours/Minutes/Seconds), then select either “Set long” or “Set Lat” to enter that value into the lower boxes. Then type in your altitude and hit apply.
Yep, use the up/down buttons, don’t type the numbers.
Great stuff thanks, its now sorted :smiley:
Can anyone point me in the direction of were I can find out what my lat/long is?
I have found a couple of sites (bbc and multimap) but they give different readings for the same place which is a bit confusing!
When I put either into WD the sunset/sunrise times are about two hours out, or could that be due to not yet entering the altitude?
Oh and were can I find out my altitude? :lol:
Neil
dotty, did you see the latest versino 10.19s has a crc error check for your weather station now?
(i.e no more data spikes)
Send me a PM with your address in it and I’ll get it from a GPS map for you. The sunrise/sunset times aren’t affected by altitude, but will be affected by lat/long. If you’re in Lincolnshire I’d guess your altitude can’t be more than about 10-20 feet!
These guys have an interactive map http://www.streetmap.com/ select Great Britain, find Spalding, click you exact location on the map, lat long is in blue banner towards the bottom of the page.
Thanks guys
you were all a great help
I am gradualy getting my head around this software
Neil
