Latest zip version from here, for me, less memmory use
I had already deleted that zip file, so I downloaded the latest using the link in the other thread (NOAA) and here is a screen shot:
i do not have the foggiest idea why its doing that.
no problems here
Not a big problem, I will just stick with 10.18x. Don’t normally d/l the zip version anyways…just hope it doesn’t show up in that version :slight_smile:
i am hoping its a user error 8O
Actually I have seen this problem before…way back when I first started running WD it happened. :wink:
Installed 10.19c and got the same empty screen. Here’s what was in program error log via View – Program Error Log while the blank screen was active::
ERROR: The parameter is incorrect. at time/date 10:47:07 PM 11/6/2004 ERROR: The parameter is incorrect. at time/date 10:47:07 PM 11/6/2004
After reverting back to 10.18x here’s a tail on c:/wdisplay/programerrorlog.txt::
Resetting wind/temperature daily value , day: 5 Resetting rain daily value , day: 6 Resetting wind/temperature daily value , day: 6 at time/date 6:56:38 AM 11/6/2004 at time/date 6:56:38 AM 11/6/2004 at time/date 2:58:23 PM 11/6/2004 at time/date 2:58:23 PM 11/6/2004 at time/date 2:59:05 PM 11/6/2004 at time/date 2:59:05 PM 11/6/2004 ERROR: Unable to write to WDISPLAY.INI at time/date 3:00:00 PM 11/6/2004 at time/date 10:47:07 PM 11/6/2004 at time/date 10:47:07 PM 11/6/2004
I wonder why no one else is having problems?? I have been messing with 2 things…NOAA email reports, and the VP Forecast / Metar tags…
thats a memory error i.e a out of memory error are you sure you exited your existing version ok? what windows version?
Most of the time cpu usage is about 10%, but when the Dallas 1 wire solar is read it then shoots up to 80% to 100% and then back to 10% + or -
is that with direct web cam capture as well?
with a, say a davis VP, and no dallas 1 wire or web cam capture, cpu use is only 1 % or so…which is good …except for a spike each minute
Yep. I am not sure what the cpu was before your latest but the computer is working far better. And my computer has not crashed since either!
its good to hear its generaly working better for people!
i have now figured where i went wrong with the sunset icon
vers 10.19e finally fixes that!
(same URL, ready now)
Good morning
What is happening to me is exactly the same thing as NorCal Dan. If I sent the screen shot it would be exactly like his. I did exit before updating and rebooted several times. That was with “zip 1019a”, but I haven’t tried “c”. I’ll try later. There now way to tell if the data receive is OK, because the screen is blank except for the menu items. Like I said yesterday - STRANGE. I guess this is the stuff that drives you up the wall where it works for 99 % of the folks. By the way the OS is Win 2000 with all service packs installed.
Cheers
MikeyM
Microsoft Windows XP
Home Edition
Version 2002
Service Pack 2
HP Pavilion
Intel(R)
Pentium(R) 4 CPU 3.00GHz
3.00 GHz, 504 MB RAM
I do
EXIT – Save and Exit on WD
Stop – Exit on Client raw real timeftp vers 3.0
Then copy the new executable into the wdisplay directory and re-start WD
the weird thing is that all that changed in WD was the type of variable used,.,it went from integer to word…
that was alll…
now, can you check with task manager, what the memory useage is?
also, try:
install, using the latest wdisplay32.exe, to a new directory, as a test
then unzip the WeatherD.zip to that directory
then save a file called 2wd with notepad.exe in that directory (just with a few letters, like blah , in notepad.exe)
so that the file ends up being callled 2wd.txt
then start wd there in that directory, as a test
Nov 5th @ 8:17 PM = 27,724
Nov 6th @ 6:48 AM = 35,352
Nov 7th @ 10.00 AM = 41,384
Program is running minimized in the tray. Does the 3 am minimize just minimize the window or does it do something else to reduce memory? (I don’t have it checked)
you need to have it full screen,or hiden in the system tray, and then do the minimise…
try that
Just downloaded 10.19f…
Opened it to an light blue box with nothing else visible except the tool bar.
Then WD crashed.
I’m back on 10.18x
now thats the 4th person that happens to
there must be a pattern
do you use the direct web cam capture?
and which direct capture method, old or new?
and do you have ticked, in the direct web cam capture setup screen, reset after restart of wd?
No, no, nope.
Not using WD for webcam operations.
can you try this test:
install wd to a new directory (using the full installer, wdisplay32.exe)
then extract the latest .zip to there
then create a file there called 2wd.txt, i.e wtih notepad.exe
then wd should start up there like brand new, no settings
as a test
