Would it be possible to do the following on the Lg. Scr. in the LCD mode :?:
Make the space between the LCD whole numbers and the decimal pt. greater…Would be easier to read…
Barometer to 2 decimal places rather than 3…
Baro Rate not changing (stays at 10.5)
Heat index not changing (stays at 10.5)
This occurs on my system with all versions of WD…Running Radio Shack 968 type WX station…
Thanks…
C. Ritchie
windy2
April 28, 2004, 7:01pm
2
ok, done all this now
uploading a new 10.10s now
will be a few hours away
Brian,
Thanks for working on the Lg. Scr. LCD mode…
Looks much better!!!..I am still not getting 1. Temp rate of change or 2. Baro rate of change…
Should that be visible in the LCD mode???
Thanks…
C. Ritchie
windy2
April 29, 2004, 10:51am
4
try another new 10.10a beta now,.,…
should be ok
the problem with them not updating results from if you dont have the main screen as lcd’s as well
also, that update keeps the setting of lcd for the large display on program restart too
