The reading I was getting through WD for the temp sensor connected to the lab jack seemed a little high. I compared this reading to that of the program that came with the labjack and found that WD was reading a higher voltage off of the sensor that the labjack program. See the attached picture - WD has the temp at 83.3 with a voltage of 3.018 while the labjack software has a temp of 78.22 with a voltage of 2.988. Based on other temperature gauges in this room, the labjack reading seems to be the correct one.
Is there anything in WD that I can adjust the voltage read or do I just adjust the extra temperature sensor offsets in Control Panel - Offsets - Extra Temperature Offset (in 10th of a degree C), and just drop these down so that the temperatures match? Does WD just read the voltage differently? Anyone else seen this?
Thanks…
