Labjack Digital Temperature / Humidity Probe
Will Weather Display work with one of the digital temperature / humidity probes that Labjack.com sells.
http://labjack.com/files/ei1050.PDF
I can see that it supports the analog sensors, but I don’t see any place to configure digital probes.
i have one here
and it was working with wd when i first supported it.,…but for some reason its not working here for me on my setup…
i will investigate what has gone wrong…
but, yes, it works…
i.e in the labjack setup, it should show up where it says humidity 1
Any luck getting WD to work with the digital temp/hum probe? I keep trying it with each new release of WD, but I am still not getting any readings.
oh, i forgot about that
i will see about it soon
but i have to go and help look after my dad now (he has not too good at the moment)
I checked the wiring of my humdiity probe, and I had a broken wire
so now its working OK for me :slight_smile:
(make sure you have ticked you have a humidity sensor)
what do you have yours wired up?
photo?
but also try version 10.13u
as strangely i had to use that version…10.13r didnt work…and yet all i did was view that part of the source code…go figure…
I downloaded and installed the latest version of WD and now the sensor is working. The only thing that was wierd was that after I turned on the option for using the labjack humid sensor, I had to close the program and reopen it in order to get WD to display the data.
well thats good news
as i said, i am not sure what changed,
(weird huh)
but its good its going now!
