Label bug
Brain, When I attempt to set a label on my 2ND Hum Temp sensor in the one-wire setup form the extra sensors real time graph no longer shows the label solar in the lower right hand portion of the form. It changes to humidity? I remove the label and solar % show back up correctly.
the solar hum resides on a space reserved for a 2nd humidity sensor
Sorry to be so dense but what are you telling me? If I lable my second humidity sensor the solar sensor will not work?
