Thank you, and glad to see you got the unit issue sorted out! (Thanks Niko and Gus :))
You’re not the first person to request snow data, actually. It’ll come, eventually…
I think SaratogaWX explained it well, but just to summarise, the ‘horsepower’ comes from the user’s computer. The load on GoDaddy is very minimal!
Ken,
Thanks for the detailed reply how these function in the world of servers and programs like javasript.
Obviously from your templates you have an in-depth understanding.
What you say as you lead me through the process makes sense. However I know from the past that assuming something works in a certain way can be far from the truth, so I appreciate the clarification.
Similarly there are other details that in the early stages of internet access may have made a difference, like packet size with header info and all, so even requesting 5 bytes of info caused a 1 kbyte packet to go out.
This sounds very efficient. And it makes me realize how rapidly things move on. I used to scour my expensive little IBM PC hard drive for errant files that took up room. Now when I run an antivirus scan I see that hundreds of thousands of files are scanned, making it impossible for us old farts to know what they are doing, and if they are vital.
I used to be in deep as possible with knowing all the tools, suites of programming tools and all, but that was another life and decades ago, so I leave it to you guys to bring us these marvelous tools to display weather (thanks to you, Yerren, Brian and Jachym) who bring me the ones I use the most.
Again, thanks, and I await the next generations as they come by.
One item I know see is the rain appears to be rounding up. In WDL or weather display I have .37 inches of rain in JavaWDL it is readin .4 inches. I am not sure but it might be rounding up. I am using inches .
and the latest weatherdisplay with windows 7
Windgust (K1DED)
Quote from: windgust on [b]Today[/b] at 07:16:53 AM
and the latest weatherdisplay with windows 7Windgust (K1DED)
It’s rounding because because the rain data element is set for only one decimal point. Yerren is already aware of the issue so it’s on his “TO DO” list of items.
Hey guys, just rolled out an update (version 1.1.3) that fixes and adds a few things people have requested.
The HTML file had a slight change, and as far as I am aware you will need to adjust it to ensure the update takes effect. I have sent to Brian to update, or you can find it here: https://github.com/Yerren/FreshWDL/blob/master/FreshWDLmaster.html Alternatively, and probably the easier thing to do, you can just go into your HTML file and remove the five instances of: ?v=1.0.1, (which are at the end of some script urls), and the seven instances of “repo” with “cdn” (which are in the middle of some script urls). This is all that has been changed.
The config file has only got another optional field now (see below), so unless you have downloaded any of the other script files and are hosting them locally, you shouldn’t need to do anything else for the update to take effect.
The changelog can be found here: https://github.com/Yerren/FreshWDL/blob/master/Changelog.md
The main thing is that most gauges can be hidden now, using the config file. A sample config file can be found here: https://github.com/Yerren/FreshWDL/blob/master/config.js where the UV and solar gauges have been disabled (as this is what most people needed).
The syntax for doing this can be a bit confusing, so if anyone wants help disabling any other gauges, just let me know!
I have updated the WD download
easy changes, Rainfall is now correct with no rounding. Now we just need snowfall added.
Snow storm arriving Wednesday.
Able to remove gauges.
Great Job !
Windgust (K1DED) Echolink K1DED-R
nice having the station name show up and the actual time of the data from the clientraw.txt file
Sweet, glad to hear it is working!
Haha to get snow gauges in by Wednesday I’d need a time machine, and a raise :lol:
Glad you noticed that
I am sure snow will come in time.
Thanks for the great work…
I will put in for a raise for you.
I loaded the files and all it says is “collecting data”. So I looked at other peoples pages and that’s all it doing too, the page wont load, its stuck on “collecting data”.
Any ideas?
https://www.northbendweather.com/FreshWDLmaster.html
Try your link again now, it worked fine for me just now:?
Nope, No ones will load for me, its stuck on that screen for some reason.
works for me ALITTLEweird1 your site
That is very strange… What browser do you use?
Win 7 IE11
Could you do me a favour and open the console (F12 > console) on one of the sites, and see if there are any error messages?
Was it working for you before the update?
It is getting closer to what we want.
Thanks Yerren!
Marian,
No errors. This is my first time loading this script. Looks like a possible IE 11 issue.
