Issue with menus
I have the latest version (Ver 10.37S116).
I cannot access either the “Control Panel” or “View” menus.
I’ve tried shutting it down and restarting and I also downloaded an installed the latest version, neither action has solved the problem. When you hover over the menus the change colour to become active but when you click on them nothing happens. The other menus “Exit”, “Setup” “Action” etc all work normally.
I suspect that they are opening off screen
try deleting the section
[control panel]
and
[view panel]
from the wdisplay.ini settings file when WD is no running
Ok yes that fixed it cheers Brian :smiley:
